Proper way to prep and break in new belt??
85K views 35 replies 19 participants last post by  DesertDuo
So I have heard you should wash the belt in soapy water and let dry before installing. I also read some people scuff up the side of the belt before installing. Also what is the best way to break it in? Just slow driving in high gear for 10 hours?
I do the scotchbrite, dawn, let dry and install. Do a couple of heat cycles and then let her rip. Basiclly the same thing you're doing Sahara just without the brake clean.
This is the way we were doing them when we raced Superlites in the MTEG series and before that series was around. We were schooled by the distributer of Salsbury clutches and belts. It cleans the manufacturing oils and residues off the sides of the belt.
One Score Offroad World championship and two MTEG championships prove it works. Will they last and work without doing it? Probably. Why do it then? Piece of mind and knowing that when we didn't do it they blew more times than not.
Bottom line, it's your car, do what you want.
I might have been missing out on some good info, yesterday was the first time I ever heard of breaking in a belt. In ten years of the UTV business, owned I guess ten UTV's over the years for business use, racing winning two cross country championships I have never broke a belt in, washed one or even used scotch brite on clutch. Never had a belt issue either. I think we sell about 300 belts a year too.
The closest thing I have done is run a wire wheel over a clutch from bench grinder then cleaning with carb cleaner and most of the time just the cleaner.
Never a issue with any of mine.
I am not saying I am right by no means, I am just trying to figure out why do it?
What is supposed to happen if you don't break it in? I guess I am showing ignorance please clue me in.
Not being a smart butt I want to know.
Todd
Todd, I have seen these post before about new belt installation and wondered myself about the break in. I thought I was alone in wondering why, not saying that I'm even close to being correct, I always thought is was what dune riders do. I'm looking forward to some explanations as to the theory.
#15 ·
Use warm water, dawn and the rough side of a sponge to scrub it with. Rinse the soap off and let it air dry. Once it's completely dry, hit the sides with a quick scrub of a scotchbrite pad. Doesn't need a lot. Put on the car and start in neutral. Run it up and down the shives a few times. Get in and drive it easy until its good and warm ( like 5 minutes or so after engine is up to temp), let it cool, repeat. After that drive it.
I always allow it to warm up a little before I get on the gas. Cold belts don't like big loads.
#16 · (Edited)
Yes, wash/scrub with a brush, with hot water and dawn, or some other good dish detergent. Rinse with hot water and air dry completely before installation.
Reason for this, is to clean off release agents(oils, silicone, waxes, etc..) from the belt surface it got when being molded.
Also clean the clutch sheaves with brake clean and if needed a fine scotch brite pad.
Blow out the clutch with compressed air, be sure to stand back a little or wear a mask and eye protection because it will surprise you how much rubber dust/debris comes out of your clutch with a high pressure air hose.
If washing/degrease is not done, belt will still be fine.
But, if there is any release agents,oils, grease, debris, etc, on the belt, it could cause belt to slip more then needed, and cause premature wear. Washing will make sure there is no sand, dirt, etc on the belt that will wear, scratch the clutch sheaves, or maybe get into the clutch itself and cause unneeded wear.
For your on board tool box, keep spare belt in a big zip lock baggy to keep it clean. Putting on a mud/sand covered belt will get you out of the woods, but can't do your clutch any long term favors...
Wash it if you can, it can't hurt.
jmo
#20 · (Edited)
Imo, just take it a little easy for the first tank or 2 of gas. Then drive as you normally would.
After 100-200 miles or so, belt should take a 'set' and be stretched to its normal working length and profile.
Even if the clutch/belt alignment is good, and everything is perfect, sometimes after installing a new belt, the tranny grinds when shifting.
You can chase this problem for a few tanks of gas or just drive it and shift when engine is off, or leave it in gear when starting.
In a little while your belt will be 'broken in'(stretched and taken a set) and no longer keep the secondary spinning, stopping the dreaded grind.
jmo
#26 ·
:popcorn:
So how many in this thread have pulled the bolts on the rear hubs on the outer arm and greased the bushings? The manual doesn't say anything about doing that either.:rofl3:
I have, once, and while I had the rear hubs disassembled, I went ahead and installed grease-zerks in them; haven't had the bushings out since and they're still tight.......
Cheers
#24 ·
If your roller has a flat spot it has now become a guide. Can you spin it with your fingers? Something has frozen it up if it's not turning.
#28 ·
BEWARE: Just read my can of carb. cleaner and it has a residual lubrication component! Quote "leaves a lubricating film to protect moving parts". This was in tiny little print on the side of the can. I was going to use it to clean my primary and secondary clutch sheave surfaces, drive shaft taper and such. Switched to acetone. Tx Bri
