41 - 54 of 54 Posts
Discussion starter · #41 ·
Did you have more information on this?
Sent from my Pixel 5 using Tapatalk
I’d like to know more too.
Alright guys I got the wireless camera installed and it works very well. I used the factory hole and get an excellent field of view behind the machine. Power was taken from the rear lighting harness as the camera has a very low draw. You will need to download an app on your tablet and connect to the camera over wifi. If you tell the tablet to default to this wifi connection then future connections happen without any input from the user. When on the trail you simply press the button on the launcher and it springs right up.
You can use this as a permanent rear view mirror if you wanted and could watch your buddies following on the trail while moving.
This was a very easy install.
The cameras are super cheap ($23 USD at time of writing) and can be purchased on ebay: 175°WiFi Wireless Car Rear View Cam Backup Reverse Camera For iPhone Android IOS | eBay
10 inch cheap android tablet, Avenza mapping software (free). Pulled plastic cover, cup a piece of 2x4 to wedge in the opening, put plastic cover on and secured cover to wood with 2 wood screws. Got metal plate from amanon along with 2 large magnets made to hold cell phone. Plate attached to plastic face, magnets to the back of tablet. Now its removable! Total cost 180 bucks. I also run a speedo app so wife can see how fast we are going!
Sent from my SM-G991U using Tapatalk
How did you mount the camera in the factory location? I got my cam today and just wanting idea
For All of you using an Android tablet how are you connecting the GPS? I got a Garmin glo2 and dowloaned Bluetooth gnss and GPS connector. I set up the "mock location". I can not get the ride command app to recognize my location. I am not as young as I once was, but I am not usually This technically illiterate!!
Discussion starter · #49 ·
I had made a sheet metal bracket which worked ok, I have since created a custom bracket. Created a walk through thread here you can check out:
The GPS is built into the tablets. Just make sure you buy one with that function and it is on.
thanks for OP on this thread. I just picked up a new 23 leftover pro xp sport at a steal. I knew their was a way to install tablet.
One question why not buy the tablet mounts that built into dash on amazon ? To save money or they don’t work well?
Discussion starter · #53 ·
Hey thanks and I hope you enjoy your new ride!
It was just over 2 years ago when I came up with this tablet setup for the Pro XP. At the time there were no commercial options available so DIY was the only option. I've rolled my rzr a couple times now slow sped crawling and had no issues with the tablet coming loose.
After seeing your post I did go over to Amazon to look at what's available, and personally if I had to do it again I would do it the same way i did originally. It's just rock solid and looks tidier imo. Nice to see other companies coming out with options though.
41 - 54 of 54 Posts
