So I installed some Super ATV trailing arms a few weeks back and Super ATV high clearance radius rods. After getting everything bolted up and setting back down on the ground the rear tires were dramatically toed in. The center line of the driver side tire lines up with bottom of the door and the passenger tire was even worse. I've searched high and low for any rear toe specs and have come across squat. I decided to drive down the block just to test the feel and drove across a snow packed section of road only doing about 15 mph and it spun the vehicle around instantly. I had a trail ride planed the next day so I built a quick temporary shim for the passenger side to at least get the toe in even. With the shim installed the toe in on the rear tires in still over 1.5"! Before the shim I'll bet it was 3". Has anyone encountered this same problem with their after market trailing arms?
