Front seat getting to heavey - wet... Any suggestions for getting foam and cover off of seat frame. Anyone near florida or Minnesota with take out seats for sale ?
How does the seat heaters work? Did you put a heater pad in each part of the seat?Remove seat.
GENTLY drill out the aluminum rivets.
When you put it back, use aluminum rivets again.
each section comes off separately.
While you’re in there, drill a few holes in the seat at the low spots. This will keep it from holding water for the seat foam to soak up in the first place. I did this when I installed my seat heaters and seat foam has stayed dry ever since.
