Good or bad for K&N filter on a 2010 RZR 50?
Most RZRs are at a steady WOT aren't they.:rofl3::rofl3: anyhow surely some super smart engineer could come up with something which could vastly improve on what we have now don't you think.:question:Never been inside a DYSON but from what I have seen its just a bunch of cyclone dust collectors, you can Google "cyclone dust collector" if you dont know what they are.Just had a thought so I took my DYSON house vacuum cleaner out to empty it and inspect the "lifetime" HEPA filter and I'll be damed, not a bit of dust on it. Now I have two dust creators otherwise known as dogs and every time we run the vacuum, usually once per week we get a butt load (just an estimate)
of super fine dust out of the reservoir. So.. whats my take here, this vacuum cleaner has NO filters except the Hepa filter at the top of the machine where the air exits the reservoir and it is clean after at least two years, that would be at least 104 uses. I think somebody should research this idea and build an air box similar and we may need very little air filtering and most every filter would be effective and replacement almost uneeded.
They use something similar on earth moving equipment, tractors, they only work well when at a steady RPM or steady suction is applied.
Just pulled one out of my "10" I just bought. Stickiest greasy mess I have encountered. Dirt was in the throttle body. OEM pleated paper is on it now. Along with the grumpy mod.I ordered a Uni filter for my 2011 RZR 800. Any thoughts on this filter?
down here in Ms the dealer said to use the UNI,they had the best luck with it..
I am still running the paper filter with the Grumpy filter mod on my RZR-S but I could probably get some pictures of my other ATV filters that are uni/FAB-1 if that would help.Hey hoser, can you post a pic of you cleaned Uni?? When I 1 st installed mine, I let it set 2 days,thinking i over sprayed it with the fab2...I thought I had even all around..
I use a paper filter in my mod. I made the hole so it would fit snug. I can just pull it out and give it a couple of taps and it cleans out. Cant do that with a K&N "filter". Best part is they are only $6-$8. I even wash mine out with warm soap and water every once in a while and get extra life out of it. Cant hurt the integrity of it because its just a pre-filter anyway.I just did the grumpy mod last night and went riding all day today following jeeps( very dusty)... My rzr and I were covered in dust. Airbox has a fine dust behind k&n. After stock paper filter is spotless! Do the grumpy mod, use a k&n for the pre filter, paper for the factory and you will be happy!
On edit: Your dust in the box could be because your engine is "stealing" air once in awhile from the exhaust tube coming from the clutch. Can happen under certain conditions.
I didn't just make this up. I did the experiment not a theory and it didn't take me 30 years to figure it out. Go and plug your out side source of air and start the motor. It will run. It is pulling air from the clutch air tubing. Now plug the clutch air tube. Motor will quit and wont restart. K&N in the grumpy mod starts getting plugged with dirt. Stomp on the gas, motor calls for lots of air. K&N cant supply all it so the least resistance is the clutch tube which exits the rear above the motor, the dustiest area of the machine. Oh, yes the K&N can plug to where the motor is starving for air. There is a post just today from an unhappy customer.I use a paper filter in my mod. I made the hole so it would fit snug. I can just pull it out and give it a couple of taps and it cleans out. Cant do that with a K&N "filter". Best part is they are only $6-$8. I even wash mine out with warm soap and water every once in a while and get extra life out of it. Cant hurt the integrity of it because its just a pre-filter anyway.I just did the grumpy mod last night and went riding all day today following jeeps( very dusty)... My rzr and I were covered in dust. Airbox has a fine dust behind k&n. After stock paper filter is spotless! Do the grumpy mod, use a k&n for the pre filter, paper for the factory and you will be happy!
Air takes the lease opposition to flow your telling us that the engine is going to suck the air through a hole 5x smaller ans several inches in length than the air filter that is only 1/2" thick, nice theory but I dont buy it been doing air flow for a living for more than 30 years things like that just dont happen.
I don't understand. I can plug up my snorkle air intake with plastic so there is no air infiltration and the motor will die out immediately on my 2011 50". If it will suck enough from somewhere else, why is this?I didn't just make this up. I did the experiment not a theory and it didn't take me 30 years to figure it out. Go and plug your out side source of air and start the motor. It will run. It is pulling air from the clutch air tubing. Now plug the clutch air tube. Motor will quit and wont restart. K&N in the grumpy mod starts getting plugged with dirt. Stomp on the gas, motor calls for lots of air. K&N cant supply all it so the least resistance is the clutch tube which exits the rear above the motor, the dustiest area of the machine. Oh, yes the K&N can plug to where the motor is starving for air. There is a post just today from an unhappy customer.
