Good or bad for K&N filter on a 2010 RZR 50?
Cause you got it snorkeled. The stock engine and clutch air intake is in the same box and shares the same air intake. The clutch draws it air from the same source and it exits out the back of the cab above the motor. Plug the air intake and the motor will draw air backwards through the clutch duct work. If you have completely stock air intake just plug the air slot. Motor will keep running. Air has to be coming from somewhere to do this. In this case its coming through clutch duct work backwards.I don't understand. I can plug up my snorkle air intake with plastic so there is no air infiltration and the motor will die out immediately on my 2011 50". If it will suck enough from somewhere else, why is this?I didn't just make this up. I did the experiment not a theory and it didn't take me 30 years to figure it out. Go and plug your out side source of air and start the motor. It will run. It is pulling air from the clutch air tubing. Now plug the clutch air tube. Motor will quit and wont restart. K&N in the grumpy mod starts getting plugged with dirt. Stomp on the gas, motor calls for lots of air. K&N cant supply all it so the least resistance is the clutch tube which exits the rear above the motor, the dustiest area of the machine. Oh, yes the K&N can plug to where the motor is starving for air. There is a post just today from an unhappy customer.
GJRonK
--Cause you got it snorkeled. The stock engine and clutch air intake is in the same box and shares the same air intake. The clutch draws it air from the same source and it exits out the back of the cab above the motor. Plug the air intake and the motor will draw air backwards through the clutch duct work. If you have completely stock air intake just plug the air slot. Motor will keep running. Air has to be coming from somewhere to do this. In this case its coming through clutch duct work backwards.I don't understand. I can plug up my snorkle air intake with plastic so there is no air infiltration and the motor will die out immediately on my 2011 50". If it will suck enough from somewhere else, why is this?I didn't just make this up. I did the experiment not a theory and it didn't take me 30 years to figure it out. Go and plug your out side source of air and start the motor. It will run. It is pulling air from the clutch air tubing. Now plug the clutch air tube. Motor will quit and wont restart. K&N in the grumpy mod starts getting plugged with dirt. Stomp on the gas, motor calls for lots of air. K&N cant supply all it so the least resistance is the clutch tube which exits the rear above the motor, the dustiest area of the machine. Oh, yes the K&N can plug to where the motor is starving for air. There is a post just today from an unhappy customer.
GJRonK
I didn't just make this up. I did the experiment not a theory and it didn't take me 30 years to figure it out. Go and plug your out side source of air and start the motor. It will run. It is pulling air from the clutch air tubing. Now plug the clutch air tube. Motor will quit and wont restart. K&N in the grumpy mod starts getting plugged with dirt. Stomp on the gas, motor calls for lots of air. K&N cant supply all it so the least resistance is the clutch tube which exits the rear above the motor, the dustiest area of the machine. Oh, yes the K&N can plug to where the motor is starving for air. There is a post just today from an unhappy customer.I use a paper filter in my mod. I made the hole so it would fit snug. I can just pull it out and give it a couple of taps and it cleans out. Cant do that with a K&N "filter". Best part is they are only $6-$8. I even wash mine out with warm soap and water every once in a while and get extra life out of it. Cant hurt the integrity of it because its just a pre-filter anyway.
On edit: Your dust in the box could be because your engine is "stealing" air once in awhile from the exhaust tube coming from the clutch. Can happen under certain conditions.
Air takes the lease opposition to flow your telling us that the engine is going to suck the air through a hole 5x smaller ans several inches in length than the air filter that is only 1/2" thick, nice theory but I dont buy it been doing air flow for a living for more than 30 years things like that just dont happen.
LINK TO POST
Like I said it aint a theory. And I aint got to pushing nothing especially those dirt sucking K&N's. Good gawd all you got to do is do the test I did. Common sense will tell ya if the main source plugs up the motor is going find air some where else. If it don't it quits running. The air it is finding is from the CLUTCH AIR TUBES. AND we are talking about installing the Grumpy filter mod which you probably dont have. You say you have been doing air flow for 30 years? :rofl3:I didn't just make this up. I did the experiment not a theory and it didn't take me 30 years to figure it out. Go and plug your out side source of air and start the motor. It will run. It is pulling air from the clutch air tubing. Now plug the clutch air tube. Motor will quit and wont restart. K&N in the grumpy mod starts getting plugged with dirt. Stomp on the gas, motor calls for lots of air. K&N cant supply all it so the least resistance is the clutch tube which exits the rear above the motor, the dustiest area of the machine. Oh, yes the K&N can plug to where the motor is starving for air. There is a post just today from an unhappy customer.Air takes the lease opposition to flow your telling us that the engine is going to suck the air through a hole 5x smaller ans several inches in length than the air filter that is only 1/2" thick, nice theory but I dont buy it been doing air flow for a living for more than 30 years things like that just dont happen.
LINK TO POST
I have had my filter loaded really well many times in the past never had any of the problems your describing nice theory tho keep pushing it maybe it will make you money like K&N cashes in :rofl3: on their products daily..
PilotOdyssey.com • View topic - Prefilter Mod By hoser.. RZR
Good GOD I did the test you did here is some more of the results you can see how much dirt has been in with my belt PilotOdyssey.com • View topic - RZR Belt Inspection at 1200, 1750 then 3226 miles. my filter has been plugged 3-4 times like in the last link and pics, I find about the same amount of dirt in my belt guard as I find on top of the TV in my living room after about a month if you theory was right would it be that clean, I know where the dust is getting in its leaking where I mounted the filter not the connection I made with the K&N the connections Polaris made that I didnt seal yet not spending a full day taking my machine apart chasing 1/8 tea spoon of dust after thousands of miles of desert riding.Like I said it aint a theory. And I aint got to pushing nothing especially those dirt sucking K&N's. Good gawd all you got to do is do the test I did. Common sense will tell ya if the main source plugs up the motor is going find air some where else. If it don't it quits running. The air it is finding is from the CLUTCH AIR TUBES. AND we are talking about installing the Grumpy filter mod which you probably dont have. You say you have been doing air flow for 30 years? :rofl3:I didn't just make this up. I did the experiment not a theory and it didn't take me 30 years to figure it out. Go and plug your out side source of air and start the motor. It will run. It is pulling air from the clutch air tubing. Now plug the clutch air tube. Motor will quit and wont restart. K&N in the grumpy mod starts getting plugged with dirt. Stomp on the gas, motor calls for lots of air. K&N cant supply all it so the least resistance is the clutch tube which exits the rear above the motor, the dustiest area of the machine. Oh, yes the K&N can plug to where the motor is starving for air. There is a post just today from an unhappy customer.
LINK TO POST
Your analogy has nothing to do with what I am talking about not sure why your struggling so hard to make a point about how hard a engine will suck air my comments are about what is really happening in the real world under normal operating conditions.--...
Hoser,
As a matter of fact, yes, the RZR engine will suck enough air through a small hole to keep running. I agree with you that an engine will draw from any supply with the least amount of resistance. I have attempted to plug up my snorkel with a towel and was unsuccessful as the engine was sucking air right through the obstacle stuffed in tight. Certainly that couldn't have been a very large passageway in that condition. I could only stop the flow when I covered the towel totally with plastic that would not allow any leak.
I don't imagine you would have to draw copious amounts of air from a backflow through your clutch hoses to create a large amount of dirt in your filter box since the dirty air is probably pretty extreme.
But then I'm not an expert engineer making the big bucks.
GJRonK
