when i first started playing with the bender i wanted to bend a stock cage, i bought a set of 6" radius dies and started fiddling with it. after springback and stretch a 6" radius bend in 1.75 tube will be closer to 7". the bends in the stock rzr cage are 5.25 clr when you try and bend the windshield loop with a 6" die, it looks big and fat, it looks aweful. (thats a big reason alot of the aftermarket cages are bent from front to back or a halo, because the big radius looks ok in those directions) i looked around and tried to buy a 4.5 - 4.75 radius die for my bender but nobody carried them, i talked to jd2, pro-tools and a couple others, they told me they could make a custom die in that radius, but that it would be pricey and that it wouldnt work. said it would crimp the tubing. when i built my bender i built in a little bit of drag (where and how the tubing gets pulled through the die) i also built it to work with an inside mandrel. my solution was to cut my own die so i did and it bends 1.75 with a finished clr of 5.17 and it doesnt crimp the tube. so i can bend a stock looking rzr cage.
in a cage even for small bends, you will definately notice the difference in the radiuses..
what is it you are trying to do?
when i build a cage, i first model it in cad.
if you know what your'e looking for, i could draw a couple of cage pieces for you and use different clr's and send you some 3d snapshots so you could see what the piece looks like in the real world in the different radiuses
here's an example, it's a picture of a standard cage vs a chop cage
