rolled rzr rebuild
This is a discussion on rolled rzr rebuild within the Projects and How-To forums, part of the General RZR category; Well I got it home today. A 08 rzr with 1177 miles on it that had been rolled. Picked it up dirt cheap. The roll ...
Old January 16th, 2010, 07:25 PM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
View stomper's Photo Gallery(0)
rolled rzr rebuild
The roll bar is toast and the front sub frame where the a arms attach is slightly bent. I will be making a custom roll bar and rebuild the front sub frame. My buddt has the same rzr for measurements of the subframe. Every thing else looks good. I will also need to purchase a new box as it was wrecked in the rollover. If anyone has one for sale let me know. I will post pictures of the rebuild as soon as I take some.
Old January 16th, 2010, 07:58 PM
polyol's Avatar
My RZR: 09 RZR
Member #6951
View polyol's Photo Gallery(0)
Re: rolled rzr rebuild
What new "box"?
Old January 16th, 2010, 08:07 PM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
the original box or bed, which ever you perfer to call it, that comes with it.
Old January 16th, 2010, 08:10 PM
polyol's Avatar
My RZR: 09 RZR
Member #6951
Oh...I wasnt sure if you meant the air box or whatever...
Old January 18th, 2010, 06:52 PM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
Well here's where I'm at. Finally had time to work on the rzr today and pulled eveything out of the front end. I left the diff in, I can do the work with it there. The problem side is the passenger side. In one of the pictures you can see where the guy "tried" to fix it. He never straightened anything just moved the a arm mounts and when they didn't work out, he shortened the bottom a arm to try to make it work. Well, It didn't work!
The bottom part of the subframe is bent up and in. I cut the two bottom tubes and pulled the front of the frame out 3/4" to where they are supposed to be. Next I am going to remove the two bottom tubes and the upright tubes in the middle of them and replace them with new ones, and add new a arm mounts. Once that it done I will salvage the steering rack bracket and weld it back in. I will make a new mounting plate for the diff, paint it up and put her back together. End of phase one.
Then phase two, Rollbar
Here are some pictures
I cant seem to upload any pictures. It said that I don't have any security tokens
Old January 18th, 2010, 07:01 PM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
just load to photbucket or similar then you can link to them
1 Limey in a world of Yanks
Old January 18th, 2010, 07:54 PM
polyol's Avatar
My RZR: 09 RZR
Member #6951
Yeah, try photobucket...
You might want to consider picking up a new frame...
  #8
Old January 18th, 2010, 08:37 PM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
Here lets give this a try. Thanks
RZR Rebuild pictures by blstomper - Photobucket
Yeah I thought about the new frame. If this doesn't work out thats what I will do. I don't think this is going to be all that much work. I have it figured out. I am getting my buddies RZR tomorrow to take measurements for the new tubes and If I get one more day at it I think it will be back together. I've fixed alot worse
  #9
Old January 21st, 2010, 03:56 PM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
Well, with a lot of measuring and figuring and more measuring, the frame looks worse than I first thought. So I am going to purchase a new one. Then I know everything is good. But thats ok I had bought it with that possibility in mind. Even with the new frame I am only into it for $3100.
  #10
Old January 25th, 2010, 11:39 AM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
Well, ordered the new frame today should be here next week sometime. Can't wait to get this thing done and start using it.
  #11
Old February 2nd, 2010, 09:08 AM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
Well, today is the day. I finally picked up my new frame today, along with a few plastic body parts. I will be starting to swap parts tonight. Unfortunatly I am in the middle of my work week and I am leaving town for my days off, so progress at the start will be slow #@$%&%*&. But I will be spending every waking second in the shop. I will keep updates and pictures as I progress for those that are interested.
  #12
Old February 3rd, 2010, 10:25 AM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
Well, got 6 hours of work on it last night and thing went really good. Did complete tear down of the old frame and installed everything that we remove into the new frame. The only stuff left is the rear and front suspension, steering rack, rad, bleed the brake system, and the plastic. And of course the roll cage, when my tube gets here. I would say with out the fabrication of the roll cage, it would take another 6 hours and it would be done. Especialy if we get another night like we did last night. here are some pictures, they are not in any particular order. You will have to read the caption.
http://s848.photobucket.com/albums/a...view=slideshow
  #13
Old February 3rd, 2010, 10:27 AM
c2turbo's Avatar
Feedback Score: 10 reviews
First Name: David
My RZR: 09 silver RZR"S"
Member #4335
View c2turbo's Photo Gallery(6)
We need progress pic's
life is good
  #14
Old February 3rd, 2010, 10:36 AM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
Click on the link below the reply.
  #15
Old February 3rd, 2010, 10:45 AM
chloeedad's Avatar
First Name: Gary
My RZR: 2010 RZR S Pearl White
Member #10250
View chloeedad's Photo Gallery(0)
Nothing else was bent?
Bookmarks
Anyone here rolled an s? Rznhell84 RZR-S Specific Discussion 27 August 30th, 2009 10:16 PM
Rolled another S' DWRAT RZR-S Specific Discussion 19 April 16th, 2009 08:04 AM
Rolled my rzr s pik 199 RZR-S Specific Discussion 9 March 14th, 2009 05:10 PM
Rolled RZR S EBT531 General RZR Discussion 8 September 14th, 2008 07:40 AM
Rolled My Rzr !!!! cr-star General RZR Discussion 5 April 14th, 2008 08:21 PM
