Here's a quick video of some drags of a 900s vs a xp1k. Then I load the tune and race again. All races are consistent and end the same. 4x4 races are a bit closer tho. There is more vids to come and 0-60 results.
Did you change the weights from 2/1/1 to 0/2/1 with the poo belt?View attachment 465737 About a half sec faster with popo belt..
Great to hear!! Let us know when you are ready for a complete exhaust!!Did a test and tune weekend with new BMP tune and stage 1 clutch.
Sucks that now I have to go over my suspension again because I am so much faster!
Well worth it. Also, even sounds better with the throttle wide open. Good upgrade.
BTW whats the base weight for BMP weights? 55 gram?
I have a heater installed in my 900 with thermostat bupass adapter, when I go to do real long slow climbs (major gear reduction here) I just turn it on high and helps keep temps down as well.I'm riding tomorrow at Rush so I'll see if it kicks on sooner, I also picked up some engine ice which I haven't put in yet. They claim 10-20 cooler engine temps. My 900s runs hot on long climbs and it's overheated several times. Tired of watching the temp gauge.
One left here, lol.. I've been on the fence for a couple years now but what the hell, it's waaaay out of warrenty at this point. Question. Over the winter I just installed a HMF slip on exhaust and included fuel optimizer. I guess the optimizer remaps air fuel ratio to compensate for the less restrictive muffler? Only took it up the driveway but it did feel a bit snappier, maybe it's just in my head, I donno.We have so many of these out there it is hard to imagine there can be any 900's without it!:wink
If your adding power youll want a good clutch setup to help get the power to the ground, if you have enough knowledge to an exhaust or install a tune then you can do a clutch kit it's super easy and straight forward and depending on future mods can definitely be worth the investment, I bought a tuner and clutch kit from aftermarket assassins and i am in love with the setup, and any questions and Mike will answer immediately, amazing people to deal with.One left here, lol.. I've been on the fence for a couple years now but what the hell, it's waaaay out of warrenty at this point. Question. Over the winter I just installed a HMF slip on exhaust and included fuel optimizer. I guess the optimizer remaps air fuel ratio to compensate for the less restrictive muffler? Only took it up the driveway but it did feel a bit snappier, maybe it's just in my head, I donno.We have so many of these out there it is hard to imagine there can be any 900's without it!![]()
My wife and I are not large people, I'm a buck fifty and she's barely 100 lbs. We don't carry too much gear. Our riding style is fast and aggressive, mostly hatfield and macoys type stuff. Run stock tires but might try out 28" crawlers. Other then RT pro springs and hmf slip on muffler (quiet series) no other mods to chassis, clutch or engine. So, just trying to get a little more power without doing any clutch work or other mods, which tune would you suggest?
You can make all the power in the world but if it doesn't get to the ground it will not be felt. Our power and speed comes with everything you need to get the power out your tires and really be felt. Comes with tune and clutching. If you are intimidated to do clutching don't be. It is pretty straightforward and doesn't take to long.One left here, lol.. I've been on the fence for a couple years now but what the hell, it's waaaay out of warrenty at this point. Question. Over the winter I just installed a HMF slip on exhaust and included fuel optimizer. I guess the optimizer remaps air fuel ratio to compensate for the less restrictive muffler? Only took it up the driveway but it did feel a bit snappier, maybe it's just in my head, I donno.We have so many of these out there it is hard to imagine there can be any 900's without it!:wink
