How do you change tires at home and what's the worst nag?
Got it! Thanks for reply!I use harbor freights tire changer that I have mounted outside on a tree stump for non beadlock wheels. It has always worked like a champ
For beadlock wheels, nothing special is required for changing tires. If the inside bead is difficult, a simple floor jack and ratchet strap can be used to break the bead.
I don’t know about others, but yes I have an air compressor that will carry any kind of air tool or equipment. It’s one of the most useful things you can have in your home garage.
Oh boy! I'd get a heart attack if anybody would approach RZR rims with a sledge 😂😂There’s really nothing to changing tires if you know what your doing. Simple tire irons and a sledge will do.
I've done this before but used a 2x10 instead of plywood. Worked great.I've heard guys use plywood board on the edge of bead and drive on with a truck
I bought this to change tires on my ATV. As I pushed down on the arm it started moving and I'm thinking "wow, this thing works great!" ...turns out the tool itself was bending. It wasnt able to break the bead on a standard ATV aluminum rim. So I returned it and used the 2x10 method (see above)![]()
PITTSBURGH AUTOMOTIVE
Bead Breaker
Yep, these work pretty good.Ive had good luck with this.
Tire changer
I bought the beadbuster after joe mentioned it on another thread. I use it 2 or 3 times a week changing tpms sensors. Love it.For anyone that keeps an assortment of tires 🙄 or changes them often the Bead Buster is invaluable. Used with an impact wrench and you can have the tire off quickly. It's small and easily stored without taking up space. One of the best tools you'll own. 👍
Well, thanks for opening that box! 😄...A UTV version Rabaconda would be a good idea.
Yes. But you also need a real hose. Those curly ones don't push enough air for a good air gun.Do UTV owners have usually a decent air compressor available at home to use pneumatic tools?
Ahaa! So we've got to specify pretty clearly what air compressor setup is needed. Thanks for pointing out this!Yes. But you also need a real hose. Those curly ones don't push enough air for a good air gun.
Fixing the HF base board under the truck is a neat trick actually!!I've done a couple dozen sets with the ole trusty harbor freight tire changer without any problems.
Supermidg what are you putting on the wheel to keep from scratching? I just put tape on the star thing. I like that.
