2024 RZR XP 1000 Possible Linkage Problem
2.3K views 24 replies 7 participants last post by  Sweetlou
Hello,
I have had this happen a few times. It's happened only a few time but I put the machine into 2 wheel H to take off and you hear a sound like a grinding and it is not in gear. You move the handle to park and back into H and no more issues after that. Well, yesterday I was cruising at around 30 mph, and coasting to a stop at a view point when it started making that noise again until I came to a complete stop. I placed it into Park then back in H and it was fine again.
What could be causing this is my question. I thought of a linkage issue. Any thoughts?
Put it on flat ground shut it off. Put in high gear. And walk around to rear passenger side and wiggle the shifter linkage see if it is locked in a gear on needs a little wiggle to make it click. Is where I would start.
#21 ·
I took a look at my linkage and everything looks tight
You have to adjust it, not look at it.
This is classic of the linkage not being adjusted correctly. The trans will pop out of gear on deceleration because the linkage is not fully engaged in the detent.
