2019 Rzr Turbo S Check Engine!!
4.4K views 6 replies 2 participants last post by  DuranturboS
Hello i got a check engine light on my 2019 rzr turbo S less than 100 miles. This check engine turns on only when am going 35+ mph. Checked the code and it says P302 misfire. What could it be? Thanks in advance
Pretty good chance it’s your drive belt, did you break it in correctly, and have you been using H gear at low speeds, climbing hills, or in deep mud? Or otherwise smoked/slipped the belt?
Any other symptoms that come with the code?
Hey thats exactly what is happening did not brake in correctly, and I transport it on a toy up rack and when i put it up it smokes. Pretty sure is the belt. Thanks for reply thats what it does exactly
Can you elaborate on that weird noise a little bit? Or post a video of it even.
Also, when you put the new belt on, blow out your clutches good, and remember to scuff the sheaves with scothbrite and clean with denatured alcohol, then break in the belt with easy riding conditions and varied RPM for at least 25 miles or so.
