Have a 2010 RZR-S 800 with intermittent engine starting problem. Bought the machine used, and it was abused by previous owner; however, in spite of my upgrades and repairs, the problem before the repairs/upgrades still persists.
The engine turns over, I have RPM's registering on the Tach, but sounds and acts as if I have no compression. This has happened 3 times since Veteran's day in November. Engine wouldn't start for several days after initial problem occurred. This problem is not a constant problem, so I'm having trouble narrowing down the issue.
I have rebuilt the top end with new JE Pistons, rings, wrist pins, Cylinder, valves, valve springs, valve seals, plug wires, NGK plugs, and replaced a bad Engine Speed sensor and cleared the code. Engine has good compression. After putting the engine back together, on one my attempts at a break in session in the garage, the engine did the same thing, turned over, wouldn't fire. I checked fuel pressure, 39psi. Checked spark, had good spark. Checked spark plug wire resistance, was a little out of speck, so replaced old plug wires. This did not fix the problem.
On my 2nd 5 minute session of engine break in period, I started the engine and the throttle was stuck wide open, but this was my fault, I was in drivers seat messing with something and pushed the throttle pedal to the floor then my foot slipped off it and it slapped back to normal and that undoubtedly did a number on the cable. I traced out the throttle cable, and found that the throttle cable had come out of the throttle plate. So I bought a new throttle cable guide and put the cable back into the throttle plate and have not had a throttle problem since. I have noticed a hi idle of around 1350-1370rpm's. But not sure what the idle was at before I started this journey. From what I've read, the throttle body assy has to do with hi idle, perhaps I need a new throttle body assy, but don't think that's what is causing my starting problem.
I initially thought it was a moisture problem because the previous 2 times the problem occurred was after riding through skid plate deep creeks, and 5" of snow respectively. But, then I remember it occurred during engine break in session in the garage, and I had the problem occur this past Saturday when the machine was in my garage and dry.
This is what I've done so far for trouble shooting:
Ohm'd out the CPS, Spark plug wires, Coil (primary side), fuel injector wires, all OK
Checked continuity from all quick connect plugs wires back to the ECU and to the grounds, they all checked good.
Unplugged CPS, engine wouldn't start, plugged it back in, started fine
Unplugged each plug wire (one at a time) engine idle changed and returned to normal after replugging.
Unplugged injector's one at a time, engine responded as expected and returned to normal
Unplugged fuel pump, engine responded as expected and returned to normal after being replugged.
Unplugged TBAP, engine did not change idle or running characteristics (is this normal?)
Unplugged TPS, engine would not start, plugged back in, started and ran fine.
Have pulled the wire loom off all wiring and checked for something grounding out to frame or something metal. Have checked continuity on about every wire in the system back to its next terminating point, have not found any abnormality's.
This is the ABNORMALITY'S I have found:
The Engine Speed sensor quick connect plug on the source(ECU side) of the plug has some bare wire's exposed at the plug, not in the loom. And the Transmission position sensor wiring has some insulation rubbed off outside the wire loom. I had these wires in the clear the last time the engine acted up and wouldn't start. I also found about a 1.5" slit in the breather hose from the air canister to the valve cover, that might be having something to do with the hi and sporadic idle and running, but not the starting issue.
I took it by the Polaris dealership and had the mechanic start it and see what he thought. Of course it wouldn't replicate the starting issue. And I havn't found anything that would make it replicate the starting issue, it's very intermittent.
The mechanic said to check the TBAP wiring because he has replaced that wiring more than anything, has a tendency to break down at the quick connect. I ohm'd all that out and wiggled it around as much as possible, it seems fine.
I had read on forums of a similar problem and the member had a ECU yellow wire rubbed and grounding out by the shift cable, so I paid special attention to that area being that I had to replace my shift cable because it was broke and out of the adjusting/securing plate. The mechanic also said that my starter sounded like it was lagging, but I wouldn't think if it was the starter it would be making engine RPM's even when it didn't fire up? I ordered a new starter just to have one, but I don't think that's my problem.
Any suggestions and advice or knowledge of this problem is greatly appreciated so I can get it narrowed down before I buy a new Throttle Body Assy, TBAP sensor, and all that jazz. It's come to the point of just replacing parts until the problem stops, but I have neither the budget or patience for that, so...PLEASE HELP!
