zerks
1.7K views 8 replies 6 participants last post by  Rodneysj
The zerk on the lower part of the rear a arm nearest the front of the machine is too tight to get the grease gun fitting on the zerk, any advice?
changed that zerk to another 90 angled but put the angle on top vs pointing down. works now without jacking
This made me crazy for a while too. In the end I have to jack it up so wheels are just off the floor and then remove 1 shock bolt. Doing both of these things lets the a-arm fall down lower which makes the zirk point in the right place to get to, even then it's really tight. I needed to do both of these to get the grease gun fitting to snap on. I think Polaris mounted the 2 zirks just a little wrong and made it a pain in the ass to get to.
Flexible grease gun hose.
My friend and I tried every grease fitting and hose we could find and still could not get it to snap on the 2 zirks without jacking all the way up and removing 1 shock bolt to let the a-arm fall down. I thought i was being stupid or going crazy for something sooo simple, so i called a friend over to try and he went through the same thing.
