So my stickers are peeling,I want to take them all off,on the plastic they peel off but on the doors they are not coming off and there is glue all over,anyone know how to take the stickers off the doors?thanks.
Use a heat gun on low settings and whenever you peal stickers off, it is best to pull back as you lift up. So when I mean pull back, it is a pulling towards you action and not just pealing back
3m makes a decal remover that goes into a drill. If you plan to re wrap is then it should be fine. Everyone recommended it for my trailer, but the paint was so thin n that it smeared it. But it's made for automobiles
Prep-All Wax and Grease Remover by Kleen Strip works well for softening and removing the glue. Not sure if it will affect the plastics tho, only used it on automotive paint.
