why the change?
5K views 36 replies 19 participants last post by  RIVERBRAT
why did polaris remove the oil canister on the 2013 xp? im guessing it was because people were adding to much oil not reading the directiuons on how to chek it. does anyone know the real reason?
#15 ·
Several forum members stated in the above referenced post that their oil lines had came loose.
I'm pretty sure Polaris didn't go backwards in switching to the wet sump motor in 2013. If it wasn't good and about moving forward they wouldn't of changed it. As far as power loss there isn't any... People are baggin on the 13' because they don't have one! The 13' has some other benefits also, bigger studs for the wheels, and I'm sure some other stuff too.
G
#22 ·
According to Polaris they changed back to a wet sump because
1) it increased bed space
2) wet sump is easier to service( search oil change questions here..a lot of people apparently had problems with correctly servicing the dry sump)
3) it slightly improved CG ( this one is almost laughable IMO but probably true at least)
G
#23 ·
Don't bet on it..ask 2010 sportsman 850 XP owners..2009 had 4 disc brakes..2010..3...there were a few other "disprovements" from the 2009. Don't assume with Polaris that everything about a newer model will be as good as last year..much less better. In my experience they usually improve some things and sometimes go backwards on other things.
