Wanting to to do a gsxr swap in my rzr
1 reading
19K views 11 replies 7 participants last post by  Zach.swihart
Looking for a kit or advice on how to go about doing the swap . I've already have the motor and wiring harness from the bike it's a 06 gsxr 600 . And the rzr is a 09
Most of the off the shelf kits available are for CVT aftermarket motors like the Suzuki built Arctic Cat Z1 and the Yamaha Apex. In fact, I don't know of a kit for a street bike motor swap. There are several street bike powered RZR's but I think they are all one-offs. Working around the chain drive and potentially loosing reverse and 4wd are probably the reasons why. Good luck tho, sounds cool.
#4 · (Edited)
Weller Racing has the bearing carrier, etc. you need for chain drive or can go gearbox from RPM if want to keep reverse. I have had both and prefer the bearing carrier as it keeps things simple and don't miss reverse (or 4wd). Its nice to be chain drive, no worries about belts/CVT tuning. Best advice I can give is do not try to stuff in the driveline with close clearance to chain, open it and give proper clearance and a little length ... actually, best to just chop rear off and use real metal rather than a hack job.
