Under Seat Storage
7.8K views 13 replies 3 participants last post by  sdc3000
What are you all doing with the storage area under the drivers seat?
I have seen storage boxes that are weather proof for the rzr s and 4 but nothing for the XP.
Are there any available for the XP?
That looks almost like an upgraded battery box but if it's not I'd be interested in knowing if it fits the XP's as well.
That one won't. On another web site said for S or RZR4. The "tab" on the corner is in the wrong position for the XP. I have looked but can't find anything for the XP yet.
Walmart sells some waterproof storage boxes that are their version of Pelican Case or Otter Box only much cheaper. There are several sizes and I found that the second from the largest at $8.89 fitst almost perfect in that space and then you can put a second box that's the same size square but only half as thick in right beside it. My Walmart was out of the thinner thickness one so I used a similar sized small parts box (not quite waterproof) as an example and took some pics while I was taking pics of my new turn signals, interior lights, and fuzed power distribution block. They are the 15th, 16th, and 17th pictures down from the top. The Walmart box is red but I also have a blue one.
ATV: 2011 November 14: Installation of LED Turn Signals/Park Lamps/Hazard Flashers, Fuse Distribution Block, and Interior Lamps on 2012 XP900 - SouthernGypsy's Photos
Would anybody happen to know the dimensions of the under seat storage area? I am away from home and unable to measure. Maybe I can find some sort of a container that will work but need to know the dimensions.
This is for the rhino and may work. This one measures -- Dimensions: 12” L x 8.5” W x 12.75” H
It's 7.5" deep down into it, just under 7" front to back, and just under 5.5" side to side if you don't count that little notch that sticks out between it and the battery which a shaped box might could also take advantage of.
