Type of gas for RZR
11K views 47 replies 31 participants last post by  duneodan
What type of fuel does everyone run in there RZR? 87 - 89 - 91 OCT
Team Red-bull
if you dont use it for awhile, treat it... if your worried about it then i think 91 is ethanol free.. there is many many debates on ethanol do some reading and form your own opinion. i work in the boating industry where boats can sit for months over the winter. some say they have had problems many have not. imo for you to truly have ethanol problems the machine would have to sit for months without ever being moved
All grades gas have ethanol unless its recreational non ethanol gas
Simple fact is that ethanol has higher octane and cheaper than rbob( reg gas)
It replaces mtbe and economically makes money for blenders to use ethanol
US uses abt 4 % blend just as oxygenate the rest up to 10% is cause they make money from it
#29 ·
That's because your wallet is so much lighter for spending more on the 93 octane! Duncan is right. Our RZR engines run best on 87 octane fuel because they have a modest compression ratio. I run 87 octane with no ethanol.
My dad had to sign a waiver when he bought his new 570 RZR. The waiver stated the dealership could deny fuel related warranty claims if fuel containing ethanol was used in the machine. After our last ride, my dad left his 570 sit for about two weeks. It then took about ten minutes to get the machine started...his last fill up was with ethanol containing fuel. Another guy in our riding group had the exact same problem with his new 570. Machine sat for 2 weeks after the trip and wouldn't start. Ethanol is crap!:rm_thumbdown:
93 and with every tank we put some Lucas Oil Octane Boost in.
#23 ·
LOL...you guys that run anything over 87 octain on the 10 to 1 compression RZR engine are completely wasting your money and making LESS hp. I build and dyno tune motorcycles and as long as a engine has low compression like the RZR, lower octain fuel makes more HP. The only reason to run high octain fuel is with high compression or forced induction applications. The other day a guy came in with a hayabusa and we made some dyno pulls on 93 octain(168hp). Then drained the tank added 87 octain let it idle for 5 or so minutes and made another pull on the dyno(170hp). I've seen this time and time again. Your RZR engine will be the same. Now if you raise the compression(this makes more HP)93 octain or higher may be needed or the fuel may preignite before top dead center. UNLESS YOU MODIFY YOUR ENGINE MAKE MORE HP AND SAVE $ WITH 87 OCTAIN.
#28 ·
Funny you say that... I raced (harescrambles) for 2 years with a Z400 with a 434cc kit at 12.5:1 compression supposedly. It ran best on 87 octane fuel. The design of that combustion chamber doesn't need much octane...
My TRX450R though - that needed 91 or better in stock form, or it ran like crap.
I work for a manufacturing company that builds parts for Polaris' atv line and I've talked to Polaris engineers about this as they come in because they see my pictures of my riding trips on my toolbox as they walk by and they said it honestly makes not much difference running 87 or 93 in the 800. And that is fine. As long as mine runs fine and performs how I ride its fine for me
Sent from my SCH-I535 using Tapatalk 2
#41 ·
MS109 has very different properties in it compared to regular pump fuel(87-93 octain). True that MS109 will give a slight HP increase as well as other oxygenated fuels. 10% ethanol in pump fuel only raises oxygenation about 3.5%. MS109 raises it by 10-12%...Be careful running high oxygenated fuels in that they make a little more HP and torque but they also change your air/fuel ratio. They will make your engine(whatever it may be) run leaner. If an engine runs to lean it will burn up. The injectors are prescribed to flow from the factory depending on rpm, throttle position, load on engine etc., a certain amount of PUMP fuel to keep the air/fuel ratio I'm guessing around 13.5:1. Raise that ratio to around 15-16:1 and pop goes the engine. 10% increase in oxygen usually walks the jagged edge. 3.5% from ethanol only slightly raises it. And our machines are probably tuned from the factory with ethanol fuel. They are not tuned with exotic race fuels. I would have my machine remaped if I was going to run high oxygenated fuels.
#44 ·
Looks like I may have drawn out one of the smart guys here. LOL
I compete in jet ski freestyle competition in the S.E. on a Yamaha SuperJet with a DASA 1200 twin engine. When I finally saw the light as to the gains from VP's oxy fuels I went through one hell of a learning curve. Stupid me thought the carbs were all that would need my attention. As it turned out, the carbs were close but my MSD total loss curve was way off for the added oxy characteristics. Once everything was dialed in for the MS109, it made ALOT of improvement for my setup. Now I see my fellow competitors killing themselves trying to complete flatwater back flips with av gas and I just get a silly grin on my face.
