Turn signal kit
20K views 45 replies 24 participants last post by  tschram2
Has anyone installed a turn signal kit in their Xp Pro yet? I have looked at the Xtc plug and play kit and the Corbin kit Is either one better than the other? I picked my my XP Pro yesterday and thinking is to put anything on that use switches to put it in one time, it looks like a big process putting in switches? Any input would be greatly appreciated.
Sorry I have not installed either kit on an XP Pro. However I have looked at these kits and stock them and either kit will work great. Both have quality parts and function is about the same. Please call or PM if you need any more info than in the link below. Forum discounts apply.
Not a Pro XP but a XPT4 - no matter. I have the XTC kit and it is easy to install and works ok. However it is not waterproof and when it gets wet (washing) the turn signal relay toggles on/off by itself. Once it dries out it stops but it has always been a concern. I have heard numerous others with the same issue.
Installed the XTC in my XP Pro. I order the XP Pro version and the box they shipped said XP 1000. Installed just fine. Drilled a couple of holes for the front signals and mounted the horn. The whole project took about 3 hours. I tend to spend a lot of time routing cables and adding protections where wearing might occur.
My suggestion would be installing all your wiring items at the same time if possible. Taking apart the center console and dash over and over is not fun. I pre-ran a bunch of rockers and cabled them to areas I knew I would be installing lighting in the future. Rock lights, light bar, interior lights, etc..Made for quick connection when I actually bought the additional lights.
I bought 4 of the "Nilight 10011W 16AWG Wiring Harness Kit" from Amazon and pre-wired those.
642913
642914
642915
Cheers!
Jakef where did you have the mustache light converted to make work? that is neat. That's the bumper i am going to put on mine when it comes in. so it makes me wonder if the lights corbin give you if you would see them.
Dave, The bullet lights are not overly visible with the bumper. I've seen several people mount them in the bumper itself, that's what we did on dad's last rzr. I was wanting something like the turbo s have with fang lights. I saw some custom work Zac Wagz Wagner on Facebook had done and asked if he could do two for me. He had a light and converted it, sent to me and then I shipped my core back to him to be converted for dads. We talked in between and he made a couple changes on dads that made it even easier for connecting. Dads light uses the factory plug on the stock light to power & ground it and only adds two wires to trigger left or right amber. If you decide to get one and don't have FB I can get you his contact information.
Is anyone doing the mustache light as a kit? Or do you have to send it to this guy for custom work? I would like mine like this also. I am off the grid and do not have Facebook. Would you mind sending me his contact information?
Check out SuperATV’s kit
#21 ·
@bug1964 does your XTC have auto cancelling??
#22 ·
I put the Corbin kit on my 19 xpt4 and it works well, I put the front lights in a different spot because my bumper would have blocked them. The instructions are good and the switch or switches are no problem to install.
#26 ·
We have the Ryco self cancelling kits also:
#28 ·
I bought the complete kit from Ryco thru Craig at utvproparts. The headlights where done buy someone close to me in southern Cali, they now make some headlights that I have seen on eBay that you all might want to check out to add to the kit, if I was doing it now I would try the eBay headlights out.
#30 ·
#33 ·
i had recently installed the XTC Self Cancelling. couldn't be more pleased. and thank you @craigstumph
#35 ·
yes. its the tan wire and connected to pin 6(??) in the cluster
