Well after much debate on what I wanted to do for limit straps in the front I decided to make my own strap setup like I did on my rs1. I refuse to give ST any of my money even if it is a well made kit. As for st spring kits I have been there done that and never again. I'm running eibach springs on both my rs1 and turbo s. My turbo s I'm running a 8" 300 over a 10" 300lb spring in the front with 2" of crossover @ ride height and it works awesome! the rear I'm actually running a stock lower spring and a rzraid tender on top and it works very good. The rear setup was temporary until eibach springs came back in stock but it works so good I will probably leave it alone. If I do anything I may just add a crossover ring to the back to be able to bring in the main sooner because it's very soft. As for the sandcraft kit I think that strapping up the suspension in the front 2.25" is a bit much. 2.25 " is damn near 5" at the wheel so that seems crazy short. Cheap 2 or 4 ply straps will most definitely stretch especially on the front due to leverage forces. I ran 6 ply trail gear straps on my rs1 and they haven't stretched at all yet after 2000+ miles. My big thing is I want adjustability because for me I never know what place I may b and what situations I may get into. I also decided to do my upper strap mount to the frame with a adjustable clevis and not to the upper shock mount. This is how my rs1 is and it worked excellent. My parts list is as follows and all in stock at summit racing just down the street from me.
*Trail gear 16" limit strap x2
*Trail gear limit strap clevis kit x2
*Trail gear limit strap universal mount x2
*Allstar performance steel 1" long tapered spacers with .500 hole x2
*Arp m12x100mm bolts x2 (polished)
*Arp small od stainless washers x4
In total my parts list is 147 dollars for everything with my discount. I will be hopefully getting to making this setup early next week. Here is a picture of my rs1 with a very similar setup that I made. I will probably cheat a little bit and not make this a bolt on kit. I will most likely be welding the upper clevis mount directly to the chassis unlike how I did my rs1. With this setup I should be able to go from 1/2 of the shock strapped up to 3" depending on my needs. I know with my rs1 I normally run 1/2 strapped up.
