Boost is calculated on a pressure combination of atmospheric air, plus the boost amount requested... it's one big number lumped together. The factor here is your baro pressure. Air temps and altitude have huge impacts on what your boost numbers are.
The 2017 models call for roughly 29psi over 8000rpm. So lets say you are at 1000ft with a baro pressure of 14. Subtract the 14 from 29 and your calculated boost pressure the turbo needs to make would be 15. Actual boost will read slightly lower... normally 14.5. Now take a hike up the mountain and your baro pressure is at 12psi. Your boost pressure will make up the difference for the lower baro pressure to try and reach 29 overall PSI, so you will see 16.5psi on the boost gauge.
Keep in mind the factory puts an altitude map in place to keep things a little more "in check" and actually cap boost numbers based on the baro readings.
The simple version... boost can vary!
2017 XPT Stock - 13-15psi
2016 XPT Stock - 10-12psi
