Tender Spring Swap Issue
2.7K views 4 replies 5 participants last post by  CyborgPirate
Hi all, I’ve just completed the tender spring swap with springs from rmatv.
After the install the front shock spring plastic slider now rubs on the shock body, any idea how to fix this? I have made sure the upper and lower spring ends are opposite each other. Are the new tender springs too stiff? I may just go to a full eibach spring swap if I cannot stop the rubbing. Thanks
What RWB713 said. Clocked 180 degrees isn't always the right answer; sometimes they need to be 90 degrees one way or the other or even at zero. Every setup is slightly different. I also found that the orientation of the arrows in relation to the shock did change the alignment (ex: arrows in line with the car front to back or perpendicular to the car side to side).
You can play with it to make it better, but this is considered normal. My rear shocks I tried about everything but couldn’t get them to not rub some. Just make sure you wash in there to get the dirt out of the slider. People have issues rubbing through the shock body when they don’t clean in there decent.
