Steering Rack
1 reading
14K views 35 replies 7 participants last post by  RZR Rocks
I have a 2012 RZR 570, the steering rack has went bad (lot of SLOP inside of rack) so I'm going to replace it. My question; is the steering rack from a RZR 800 tge same as the 570? I've read different theories on this, I've read the only difference is the tie rods but the actual rack is the same. They say the part numbers are different between the 2 because of the tie rods. I'm looking at the Super ATV "Rack Boss" but it is supposedly only for the 800 & other models but not made for the 570, or is it? I have a friend who is a Dealer for
Super ATV & can get me a great deal. Please let me know if any of you have ran across this, Thanks.
Mine had quite a bit of slop in the Input shaft & on the driver side & all was due to the Top bearing was worn out I replaced just the top bearing & cleaned & lubed the rack works fine now I got the bearing from NAPA Part# P6202RSJ,Mark the Input shaft cap then unscrew it I used a punch & hammer then input shaft can be removed There is also a small needle bearing @ the bottom of the input shaft Mine was Ok not sure where one of those could be purchased? when reassembling put cap back to where it was (align the marks you made))
It was just the Upper Bearing that was bad on My Rack it had Play @ The Input Shaft & The Left side if the rack had up & down Play all due the Upper Bearing once it was replaced & cleaned & Lubed it was good all play was no longer there,Very simple Rack with few components but Polaris dosen't sell any parts,The Parts are: Upper Bearing (Got it from NAPA #P6202RSJ) The Lower Needle Bearing Mine was ok not sure where one could be purchased, The Rack it's self & The Pinion Gear & The 2 Inner Tie Rod Ends ( (available aftermarket) & the 2 Boots, What surprised Me when I removed My Rack Assembly & started tear down was it was full of water & I am not much of a mud rider,easiest way to check upper bearing play is with RZR not jacked up take a light & look at the input shaft of the rack (where the shaft from the steering wheel connects) have someone rock the steering wheel back & forth a bit & look for play if there is a good bit of play the bearing is bad,to change the upper bearing the top cap unscrews use a punch & hammer but mark cap & rack with a center punch 1st & reinstall cap aligning the marks after changing the bearing if overtightned it will put too much preload on the bearing & cause binding.
I'm going to tear into my rack 1st & try to fix it 1st, but if the 800 racks are the same (as some say) I wonder why SUPER ATV doesn't sell the "Rack Boss" for it? I've been told the only difference is the tie rods but I've also been told that the steering shaft also has a different part number as well. So that makes me wonder if the input shaft is located differently between the 570 & 800. It's worth the effort for me to find out because of the price I can get the "Rack Boss" for. If the end result doesn't work to fix mine or I find out that the Rack Boss for the 800 will not work then I will definitely look into purchasing the Rack Zilla over the OEM.
Ok, I installed the Heim (tie rod) joints on top of the steering knuckle instead of underneath. In the instructions it says to mount back in factory position, but after I did the joint was extremely close to one of the brake caliper bolts, so close that I would have to pull the tie rods everytime I had to pull the caliper to grease my front bearings (which is about every 3rd-4th ride). So I talked to a tech at my local Polaris dealer & then I called SUPER ATV & spoke with one of their engineers, they both agreed that there would be no problems with installing them on top. Plus the angle & stress is less on the inner & outer joints being mounted on top. So hopefully it will also prolong the life of the joints. I haven't rode it yet but will hopefully be out in it this week.
How about you guys, have you experienced this as well, let me know, Thanks.
I haven't done this on a rzr but I have done the exact same thing on lifted trucks. Flip the drag link/tie rod end from the bottom to the top of the steering knuckle. It definitely helps prolong the tie rod end life on a vehicle and helps with bump steer due to decreasing the angle on the joint. The more inline you can have moving joints the better.
#21 ·
Steering Rack & Heim Tie Rods
Ok, I've driven it up & down my road some. Could be me, but it feels like there is more body roll in the front now. I have read on here somewhere last night about the Heim tie rod ends toe in & out fluctuates as the suspension goes up & down. I find this to be true because when I pick up or push down on the front end the toe in does fluctuate, it just doesnt look right. Now I did mount the outer Heims (tie rods) on top of the steering knuckle instead of underneath after talking to a mechanic at my local dealership & one of the tech guys at SATV. Could that be the issue or is it the nature of the Heim tie rod ends or is there nothing wrong at all? I never paid attention to the toe movement before all this. Thanks again for your help.
#26 ·
There's definitely a difference in the angle, & yes I am running the small adapters. The problem I'm having now is the bolts are not long enough to put the cotter pin in it, SATV sent new hardware but they missed the mark on where the hole was drilled in the bolt. I'm just going to get new from FASTENAL tomorrow. Have you had any issues with your Heims, I've read some like them but some don't as well.
