B Bluerazr 310 posts · Joined 2020 Add to quote Only show this user #2 · Apr 13, 2024 Quicker steering ? The steering changes if you have ride dynamics , and change shock settings .
Mattman06 1,652 posts · Joined 2020 Add to quote Only show this user #3 · Apr 13, 2024 I made a column for my pro xp with a 1.5 to 1 quickener. Not sure if the pro r column is different.
J Josesxntos Discussion starter 6 posts · Joined 2024 Add to quote Only show this user #4 · Apr 13, 2024 Mind sharing any pics? Im so used to my x3 with 1.5 quickener
J Josesxntos Discussion starter 6 posts · Joined 2024 Add to quote Only show this user #6 · Apr 13, 2024 Yup! Its the same. I want to run oem steering wheel tho. Looks nicee overall, can you link me to what you bought for it so I can try and replicate it
Mattman06 1,652 posts · Joined 2020 Add to quote Only show this user #7 · Apr 13, 2024 Multipurpose 6061 Aluminum Rectangular Tube 3/16" Wall Thickness, 3" High x 3" Wide McMaster-Carr
Mattman06 1,652 posts · Joined 2020 Add to quote Only show this user #8 · Apr 13, 2024 Low-Carbon Steel Rod 3/4" Diameter McMaster-Carr
Mattman06 1,652 posts · Joined 2020 Add to quote Only show this user #9 · Apr 13, 2024 https://www.summitracing.com/parts/brg-013464
J Josesxntos Discussion starter 6 posts · Joined 2024 Add to quote Only show this user #13 · Apr 16, 2024 I think only thing missing is the actual steering quickener and some welding right
ljrat 571 posts · Joined 2015 Add to quote Only show this user #10 · Apr 15, 2024 Mattman06, we always appreciate your fabrications and willingness to share the info!
SlowBusa08 1,077 posts · Joined 2021 Add to quote Only show this user #11 · Apr 15, 2024 any issue with the wheel violence at the faster ratio? i assume it would actually give you better leverage over the wheel? I ask because i've seen people comment that these tend to rip the wheel out of your hands.
Mattman06 1,652 posts · Joined 2020 Add to quote Only show this user #12 · Apr 15, 2024 It increases the feedback some, but I haven't felt anything violent. Mainly it just increases the amount of force it takes to turn the wheel some.
Mattman06 1,652 posts · Joined 2020 Add to quote Only show this user #14 · Apr 16, 2024 You'll need one of these alsohttps://epowersteering.com/purchase/product/3-4-smooth-x-19mm-17-spline-u-joint/
Mattman06 1,652 posts · Joined 2020 Add to quote Only show this user #15 · Apr 16, 2024 1.5:1 Steering Quickener - Keyser Manufacturing keysermanufacturing.com
