Spacers
5.4K views 22 replies 13 participants last post by  DaleB
Anyone used spacers on there trail? The good,bad any input. Also the best ones to buy if this is a good idea.
I'm interested in this answer as well. Hoping to install a 2" lift and 1.5" wheel spacers to increase clearance and balance out the extra height with additional stability.
I am running Venum 1 1/2 inch spacers on my 2017 900. I have only had them out once for about 50 miles with no issues. I checked the torque after the ride and they stayed tight. I am also running 27-9x12 Evo's all the way around. If you go with spaces, make sure that you get at least 1 1/4 inch because you studs are that long. If you get sorter, you will have to file or gride down your studs.
#21 ·
I just put the 2" lift with 2" spacers all the way around. She sits stout and runs solid in the wooded trails. Lots more stability in the hills and corners can be taken much faster. I have only had them on for one ride. But the difference was noticed immediately! View attachment 528986
Did you stick with stock size wheels and tires or change those as well? TIA
Nice RZR!, who's lift did you go with?
  • Like
Reactions: JusticeRZR
I know it is off topic, but who makes the nerf bars/rock sliders? Would love to protect the sides some but read those were incompatible with the full skid plate?
#20 ·
That's a sick looking ride!!!! Any suspension issues with the bigger tires and the 4+3 offset? Some folks said to stick to 5+2, but I really want to be a bit wider with the 2" highlifter lift I plan to install rather than trying to stick with 50" width. Thanks.
