silicone hose replacement question
1 reading
2.8K views 6 replies 6 participants last post by  talon4u2nv
Of all the pretty, shiny and expensive silicone replacement hoses for the turbo, do any of them make actual HP claims?
And is there any hose that you would consider a "must replace OEM" hose?
Thanks
the tubes by themselves don't really provide any real hp gains, what they do is allow you to run a tune with higher boost levels without having the plastic pipes blow apart. The tune is where you will see hp gains, that's pretty much how any of the upgrade parts for the turbo motor are going to be, you are technically only upgrading to support the tune level you want to run. If you don't upgrade these parts and try to run a tune that is too much boost the stock parts will not hold up to it and/or create too much heat, limiting reliability and power gains.
This, I can say do to the smoother inside and no flex sections and larger diameter. when you start running some files on the ECU you will likely get an increase in flow...I know my intakes talked more when mine were upgraded vs the stock ones.
