Shock won't line up with swing arm hole
1 reading
3K views 7 replies 7 participants last post by  i2cou4u2
Any ideas on how to get this to line up? I adjusted the ride height so the spring isn't compressed at all. Now I just need to compress the shaft to move it an inch to line it up with theswing arm hole. My shock is longer than the travel of my swing arm. There is nothing holding my swingarm from falling except for everything else that is bolted to it.
trailing arm
Tried that. Because of the angle it slides the shock back out towards the back of the sxs. Right now I'm trying to locate another jack so I can move the shock out of the way, then jack the trailing arm up so I can take out the bolt for the sway bar. It seems like the sway bar is preventing the trailing arm from moving down more.
