Shift leaver very stiff
3.8K views 7 replies 5 participants last post by  Breadkrum
Ran my 2016 xp4 1000 fir the first time in a few months, when shifting from park to reverse i noticed the shift lever was very stiff in all speeds. Any ideas on the cause and fix
Clutch not releasing completely? High idle? Does it move on it's own in gear?
Turn the rig off and see how easy it is to move between the gears. Start it up , and pull forward or reverse, then try to shift between gears with the vehicle running . If it shifts easy with the vehicle off but hard with the vehicle running it's clutch related . If it's clutch related I would clean the primary and secondary real good .
Clean clutches well (blow out dust). Collect data (idle speed, etc). Call www.Hunterworks.com
Sent from my SAMSUNG Note 5 using Tapatalk Pro
My shifter is hard to move from park to reverse to high or low and back agian, with the engine running or not.
