scrambler rims for rzr?
1 reading
6.4K views 4 replies 2 participants last post by  presumed_druid
I have a 2013 standard 50" 800 that still has original tires and steel rims. I'm looking to upgrade and have seen a set of 14" factory rims off a 2013 scrambler 850 LE that are priced right.
I can't find any bolt pattern or offset info on the scrambler... does anyone know if they'll fit and work with 26" bighorns without a lift or spacers? From what I've read here, the lift part shouldn't be an issue, but I'm not so sure about the motor mount clearance.
#4 · (Edited)
They will not fit. I have a 850 scrambler and wanted to put them on my rzr. My rzr is a '09 but I think it is the same for yours.The rzr bolt pattern is a 4/156. I wish it would fit I would run them on my rzr during the winter. Checked your model and it is the same as mine. I am thinking about going with ITP steel wheels 4/156 12x7, and staying with 12 inch tires 26x9x12s all the way around with a spare. The wheels are 37 bucks apiece and are one inch wider than stock. I run wheels spacers and a 2 inch lift. Looks better and rides better. I dont bottom out on rocks like I used to.
