sagging
2.2K views 6 replies 6 participants last post by  rkymtm
My xp1000 has the 15" MSA Loks which are pretty wide offset to begin with. but my machine sags bad all the way around. arms sit flat. it only has 350 miles on it. I've tightened down the shocks all the way around (2-4 turns). after another hard ride I'm right back down to where I was. I'm gonna keep tightening them, but I'm just curious if anyone else is having these issues. I ride very fast through a lot of rough terrain here in wv and I need the ground clearance for when landing off small jumps and the compression when going over things.
just need input. as of now I'll keep tinkering with it.
Eric@HoldersDiesel
shutup Shawne lol
My shocks were low on Nitrogen and I know of a couple of others that were the same.
Polaris had speced 200 psi then changed it to 125psi
My springs still look good, no sag so far. I am running the front helper on rear and an Eibach on front with stock main springs. 600+ miles.
I hope this is not like the previous machines with poor quality springs.
I have not seen any springs that are collapsing on the xp1000.
someone reported they had springs stamped with made in usa. mine are not.
