RZR Beer Cooler
9.3K views 22 replies 12 participants last post by  RZRider
This topic won't appeal to everyones tastes, but here is an idea my friends and I came up with. We have tried many things, but lets face it beer bottles break in the cooler so heres the new project for the home built lock and ride beer cooler.
1. take your favorite beer cooler, and place a couple of zip lock bags filled with air in the bottom to create a void. Ensure that the drain plug is covered. 2. take 1 dozen beer bottles, and cover them in grease, or pam cooking oil, or wrap them in wax paper (prob the best solution). 3. use a can of expanding sprayfoam insulation, and fill the cooler 1/4 full, remember this stuff expands quit a bit. 4. place the 1 dozen beer bottles into the spray foam and allow the foam to cure. 5. when the foam has dried, and hardened remove the beer bottles. the grease should allow you to pull them out without wrecking the foam. 6. puncture the bags of air in the bottom of the cooler, and remove them throigh one of the bottle holes. the pourpose of this step was to create a void for ice.
And there you have it ride as hard as you want without worrying about breaking the precious cargo.
If I ever get around to it I will post pics of the finnished product, however chances are one of you guys will get the job done before I do.:beer3:
Neat idea! But .....
I'm not even sure that the forn fitted holes would keep the beer bottles from exploding if the cooler were ejected out of the back of the RZR after hitting a bad hoohaw at high speed.
I was expecting a cooler that was designed to bond itself to the cargo box using the "lock and ride" system.
#22 ·
Just buy the lock and ride gas can holder for $30 bucks and go to target and find a cooler that fits in it. I have two of them and they work great! Fits right next to the Lock and Ride trunk, one on both sides. Home Depot has 2 large velcro straps for a couple of bucks that hold the cooler in place.
