I fully charged & installed my optima battery in my RZR last night it read 13.2 volts. After charging I waited a few hours before installation I checked voltage after I hooked it up before starting & it read 12.8 volts. With the RZR running it charges 14.7 volts.
When i got up this morning I checked my voltage & it read 12.6 volts. Is this good or bad? Also when I hooked up my cables last night I noticed a motor like sound coming from under the dash. It ran for a few seconds then turned off. Kind of like your car does when you first install a battery. Is that normal? I need a little help on this I just bought the battery & I am not sure if I should return it or not?
I am leaving for the dunes next wednesday & I dont want to have any problems. Any help would be greatly appreciated. Thanks
