Rotate Tires?
6.3K views 14 replies 7 participants last post by  markgam
I have a 2021 Pro XP 4 Preimum.
I still have the standard 30x10x14 factory tires on all four wheels.
Are the wheels all the same width and offset? If so, rotating the tires is simple and I'll let's Discount Tires rotate them.
Sent from my SM-G781U using Tapatalk
Do you have a jack? It will probably take more time to drive over to discount tire and back then to jack the rear up and swap and jack the front up and swap and it saves you $32.
Can you borrow or use someone's jack? I recently rotated my tires by taking my RZR and my jack over to my father's house and used his jack to raise the front and my jack to raise the back. Took about 30mins to swap the 4 (no tire mounting, already had same rim on all 4 corners).
After rotating my tires I noticed this as well, if you're going to just keep the same tire and brand, I would weigh the costs and benefits to only replacing the back tires when needed, the front tires last forever.
Idk getting some aftermarket wheels would probably be easier than doing it every single time you wanted to "rotate them" then you can do it whenever you want and do the same once your tires wear out.
If you do beadlock's then that is easier to do at home when it comes time to switch out tires, and you get the added bonus of having a beadlock on the trail.
