21 - 30 of 30 Posts
I pieced together my own system
2- kicker marine 6 1/2 km65
2- jl w1 sub
Ssv works Bluetooth control
900.5 diamond audio amp
I wasn't super stocked about the system until I added a audio control three.2.
That made a huge difference in my system. It is almost to the point it's too loud.
2- jl w1 sub
The Audio Controlled 3.2, is that just an EQ.?
I called Fosgate, the video install they put together shows starting point gain settings, so on the sub amp, he told me to move it from 7 to 10-11, and it made a diff.
Also you wanna make sure your car battery is charged well (or running) there isn't a lot of current to draw from. I trickle charged mine and tested with it charged, gains up and it's working as expected.
Now I have to button it up, install the Lowrance Baja, the chrome fire extinguishers (axis billet mounts) and I'm good to go
Was that gain increase on just the sub amp?
Also are you running a single battery? How does it hold up?
I'm about to put in the Rockford Fosgate Stage 4 and want to get it going as easy as possible
Thanks
I was just at CampRZR and Rockford fosgate had a tent there with some 2 seaters and 4 seaters. Those things sound cherry! I want there setup now. Soooo loud and sounded so much better then my pieced together 6.5 infinitys and 400-4 Pyle amp lol
I'm just running the stock battery. I ran it over a weekend a few weeks ago, and it worked flawlessly and seriously sounded good.
That sub and 4 speakers light it up.
I have the Rockford Fosgate Stage 4 and just finished the installation
I followed the the instructions in the video and overall it's ridiculously loud
The sub itself could be louder though, I may have to adjust the bass amp
There's also a point in the video where they adjust the head units gain and said don't go over three or the sub would be overpowering, maybe I'll try to bump that first instead of taking the instrument panel off again
Also since the head unit only has front out and rear/sub out, which you set to sub in the settings.
So the fader does not work to adjust the front/rear balance, it adjusts the speakers/sub balance
Here's a short video, my kid photobombs it in the middle... he hates this music and thinks I need a disco ball lol
This is great input and good to hear that most are happy with this system. TMW is installing the recently released Rockford stage 5 in my car so based on these comments it should sound pretty good. TMW said the stage 5 sub output is much improved.
21 - 30 of 30 Posts
