Hello. Per multiple web pages, "Only a Sena® 10R headset will connect to Ride Command." In the list of compatible devices, listed are Sena SMH10 and 20S. Either way, since Ride Command should basically just Bluetooth to the headset, it seems hard to believe that only Sena headsets should be compatible. Also, since people have been using other tech for communications, that Polaris would team with Sena and make a proprietary comm link would be counter to customer-friendly.
We have been using Cardo devices (such as PackTalk Bold), which are more capable than Sena (DMC mesh up to 15 riders and the ability to chat with only the co-driver, when needed). We certainly aren't going to all change to Sena, just to connect to Ride Command, but having the RC system and not using it to it's full extent is also undesireable. FYI, Cardo will connect via Bluetooth to other systems, smart phones and GPS's.
Does anyone have knowledge of
1) Does RC actually connect to other headsets than Sena?
2) If not, is there any plan for Polaris to open this connectivity to other than Sena?
Thank you all.
general.polaris.com
ridecommand.polaris.com
Tony
Virginia City, NV, USA area
2011 RZR 4, planning on a 2020 or 2021 RZR XP 4 Turbo S
Thank you all.
Connecting Bluetooth® Devices to 2019 and Newer Ride Command Displays | Polaris GENERAL
How to pair phones and other devices to your Ride Command display
Supported Devices | Ride Command
The Ride Command® app is available on both iOS & Android. We recommend running the latest OS for your device.
Tony
