Rear clicking noise in forward but not reverse
12K views 8 replies 6 participants last post by  fireman660r
My XP4 has started making a clicking noise in the rear. The noise occurs when going forward in low and high in 2wd and 4wd, but not reverse, neutral or when pushing. Any ideas what could be causing this?
Just a click or a gear grinding sound?
My clicking was the rear brake pads.
I had a wierd rear cv joint on mine. Only done it with 2 people in it, only forward and when turning left. It loaded the axle harder. I ran it about a 100 miles and it's got slightly worse. Finally sat down and looked at the mechanics of it and figured hub bearing, axle, or rear diff bearing. Swapped axles and Bingo. Hope this helps. I had no play or torn boots.
Either a CV or more likely brake pads. Only way to get brake pads to make noise is when going forward and low enough engine rpm's to hear them. caliper mounting is poorly designed and can be fixed a multitude of cheap ways, search youtube and you will find a multitude of good videos. If not pads then probably a CV
