I've read through a number of posts on this subject. I have a 19xpt that has the factory installed busbar and a Blue Sea fuse box that all accessories are wired to. One thing that I'm not quite understanding is some kits/installs there is a wire that goes from the isolator to the ACC post of the busbar and some do not (pics are below). From my understanding that wire would be to power the isolator so that the accessory (2nd) battery is on and accessories connected to it can be used when key is ON but machine doesn't have to be running. So my questions are:
1) What is that wire really doing and if not used and you simply run a positive cable up to front for a secondary power post how does that change the system setup, accessory power is always there even when key is off?
2) For those that have factory installed busbar, I'm assuming you're just throwing in another power post next to busbar and having all accessory power routed to that correct? The Blue Sea fuse box power lead in my case.
3) Whats the different of running a circuit breaker from the isolator vs a large inline fuse on the power wire thats running up to front of vehicle.
There seam to be a lot of people running the TrueAM kit so looking for any feedback. Thanks
Has wire:
Doesnt appear to have wire:
Has wire:
