i have had the the same issue, my cluster is dead, i have done every test that it calls for, but i have a bit of an electrical back ground so i took it one step further, when i tested the 12v constant on the instrument cluster plug it showed good, but when i plugged the cluster in and tested amperage when i turned the key switch on there wasn't any, so i ran a test lead from the battery to the 12v constant on the gauge and turned the key switch on and it came on and worked perfectly, i bought the test leads at radio shack for like 7 bucks and they were 3 ft long i just cut the 90's off and wired them together, it ended up being a bad splice, it comes from the fuse block then splits, one 12v constant goes to the ecu, and the other the instrument cluster.......good luck:rzrs:
