Primary Clutch Damage
2.2K views 3 replies 3 participants last post by  RWB713
Has anyone seen something like this happen before? It's a 2019 with about 200 miles on it. Got stuck in a knee deep puddle of water and mud. As I tried to get out the belt started smoking and I wasn't moving so I tuned it off and had to be pulled out. As I started moving again it was jerky while going slow and made a grinding noise. Also had a huge loss of power. Went straight home and found this. No small broken pieces could be found in the housing or anywhere. Is just the rear sheave replaceable or do I have to buy the whole clutch assembly? Or, due to the damage should I just buy the assembly anyway? I wanted opinions due to the low miles. Thx
After some research I guess this has been known to happen on occassion. Looks like time for a whole new clutch and belt. I am assuming the cold water on the hot belt and clutch caused this along with my heavy throttle trying to get unstuck. Lesson learned the hard way.
