Where are you guys getting the power for all the lights, stereo and such. Are you coming right off the battery or is there some spare connections in the fuse box. I have an 08 rzr.
that is very similar how i started building mine. Great diagram by the way!! i'll have to get some more pics later. i'll get some before i do the wire covering up.if you know how the relay works,
a. run a 10gauge wire from battery to your relay, "with a in-line fuse" high amp
b. run a 10gauge wire from relay to power a fuse block or power strip
c. ground the relay
d. use the orange wire under dash, to trigger the relay powering up the wire to the fuse block or power strip, this is a key on power wire normally taped up under dash behind the light/4wd switches with a female bullet style connector on it.
on my system i have 4 power circuits available, and 4 key-on circuits
i added a 8 fuse accessory block found on e-bay for less then $10
used 2 extra relays for less than $10 for both
i didn't use a water proof fuse block but did use die-electric grease in EVERY connection, mounted fuse block under dash on floor pan/fire wall.
been useing this set up for 6 months, no issues. although i don't drive like its a submarine either.
Thanks. It is a little dark now. I will look for this stand alone orange wire to-morrow.look under your dash where your harness connects to the switches, you'll see a orange wire not connected to anything, it normally has black tape wrapped around it to the main harness. or just hang'n loose. this wire gets power when the key is turned on. its there for accessories. follow my diagram at the top "key on +" square, i used standard relays found at local auto stores. they normally have numbers on the back labeled 30,87,87a,86 and 85.
useing the orange wire your lights or what ever will only work if the key is turned on, preventing a battery drain.
I have a feeling the dealer might have used this wire to connect to the winch that they put in for me. If it is used said:yea, i bet they used it.. just un plug it, plug the red winch wire into your new fuse block, use the orange wire to trigger the relay. that orange wire only has like a 20 amp fuse on it so it won't handle many accessories ran off it.
I am clear now. Thanks...I have a feeling the dealer might have used this wire to connect to the winch that they put in for me. If it is used said:yea, i bet they used it.. just un plug it, plug the red winch wire into your new fuse block, use the orange wire to trigger the relay. that orange wire only has like a 20 amp fuse on it so it won't handle many accessories ran off it.
awesome drawing. Is it necessary to run an 80 amp relay if I'm running a lot less accessories? I have a 40 amp and am looking to run my LED light bar said:no, or maybe? i used a 80amp cause of multiple accessories and didn't want to risk over loading the relay. i maybe only drawing 30-50 amps while driving but wanted to be safe.
you need to know how much draw each led, whip, radio, ect. is gonna have & get a relay big enough to handle it.
