Power commander fuel maps for XP
9.9K views 9 replies 3 participants last post by  Carhauler
Does anybody have a decent base map for just a yosh slip on or other slip on and an airaid or k&n type drop in filter? I got my pc5 in today but they didn't send the autotune. I'd like to get it installed but I'm not sure if it will run ok unless I have a decent base map.
Sent from my iPhone 5 using Tapatalk
There might be a map in it already, when I bought mine it had a map with it cant remember what it was. I didnt order it with one, just came with it.
Yeah it's got a stock base that's all 0's in all the tables. I just found a map for the Polaris/yosh slip on with stock air filter. I'm gonna try that one. It may be a little rich.
By the way, are these pc5's waterproof or resistant? Just wonder where I should install it
I installed it pretty much where instructions said.. They are sealed. I would not go under water with it, but I have got mine wet when washing. No problems. I have seen some people mount them in pelican cases. I dont use mine like a jetski so I wasnt worried.
Yeah I don't sink mine or anything. Just occasional stream crossing but never even deeper than the need bars. Washing was my main concern. Thanks for the help
I can't find a map on their page with anything other than stock filters and exhaust. I just got my Pcv installed and put the map for the yosh slip on and stock filter. It seems hesitant when I first nail the throttle. It almost dies unless I barely get into the gas.
Does this look ok to you guys? The auto tune seems to be pulling a lot of fuel down low. I kept the same target afr table that Nate had in the map. Starts at 13.9 at 2% and runs out to 13.6 I think
