went for a ride last night and somewhere in the rear I have a popping sound. Seems to do it mostly when Its not under any load or when I turn right and load the left rear suspension. its not in the suspension. It is a rotational noise. Any ideas?
On my 570 I also heard a popping noise and eventually chased it down to the clutch. The clutch was so worn out a weight had popped out. I stuck it back in, tried it, and within a hundred feet it popped back out. Problem solved with a new primary assembly!
I am going to say its your sway bar. Put some wrenches on all your sway bar bolts, 15 wrench and 15 socket. I would also say its your upper sway bar bolt on your driver side, but check them all. Let me know if this does the trick.
well, I found the culprit. Left rear wheel...2 loose lugs, 2 missing. bad thing is that 1 of my buddies had a loose wheel that night and I never even thought to check mine!
My 2019 was doing this, left rear suspension. Found it to be a loose bolt. Lower left sway bar. I appreciate all the comments I was ready to start a tear down.
Related Threads
Polaris RZR Forum - RZR Forums.net
posts
3.2M
members
152K
Since
2007
A forum dedicated to Polaris RZR enthusiasts! A great place to find rides, meet people, and exchange ideas / parts/ rzrs!
