I managed to break a fender mounting hole/tab on my XPT bed. I'm not inclined to replace the bed half, so I've been doing some thinking and a little research.
Here is what little I know, offered in the hopes it might help the next guy. Please chime in if you've experience or other idea's.
Background:
Our plastic is alleged to be polypropylene based, and so doesn't accept epoxy well. ( or is it polyethylene?)
Options:
Anybody got any experience or feedback to share?
Background:
Options:
- It seems you can epoxy if you heat/burn the plastic enough to change it's outer composition. Personally, I doubt this is particularly strong, but you tell me.
- You can heat weld. This amounts to plastic rod being melted in place to rebuild or repair the crack. Literally welding. Harbor Freight makes a unit, other have used heat guns and zip ties. Amazon has plenty of plastic welding rods to pick from as well.
- An allegedly stronger "welding" method, one that requires a body shop, is called "nitrogen welding" What this does is remove the O2 from the air as the plastic melts, and that eliminates char and contaminants from getting into the weld. Still pretty cheap compared to a new plastic piece, and as strong of welding as I've found.
- There is an epoxy like product that's supposed to work, although it doesn't appear to have any "fill" capabilities. I understand the company doesn't support its use for poly based plastics though, so .. Perhaps other can tell us more. It's:
