1,721 - 1,740 of 3,137 Posts
Save
does anyone have the plastic side nets that they want to part with?
Finally, I have something someone wants, yes I have them do you just want the plastic nets or do you need the tube bars that they attach to? I think the nets will fit into a large envelope. Let me know. Tim
Save
i have an 08 and i have those mesh side nets which are a pain to clean, so im assuming the plastic ones will fit. And the bars on mine are welded to the cage in one spot if im not mistaken. But yeah, ill take them!
still looking for side nets.thanks
Save
Already spoken for.
Any RZR 4 owners out there thinking about cutting down their cage, but don't have the means to do it or aren't sure and don't want to make irreversible changes, here's your chance.
I have the cage off my 4 that has been cut down approx. 6" and it will be up for grabs.
I'm replacing it with a new cage with fixed doors.
I'd prefer someone come and pick it up, I imagine shipping would be a few bucks - It's in my shop in Los Angeles.
You can kinda sorta tell how it looks in this photo. It doesn't peak in the back. I cut it down so it would fit in the toyhauler better.
That didn't take too long. The cage has found a home.
Save
need wheel flairs for an s, will buy if reasonable. have all stock a arms for rzr but the lower front right is bent, also have shocks and front torsion bar, side nets and stock seat belts, pm me please
i need some side nets still for an 08 ;)
Save
It's found a new home...
Polaris RZR light bar (small front) by SuperATV
Installed it but didn't mount any lights on it.
Running the HID lights now & won't need this.
Send me a PM with address, Thanks Wacker
Link HERE
Save
Needed, Stock Fuel tank with top..internals not necessary.. read on.......
Ok guys, After a Thread was started about fuel tanks ect.. I decides that I am going to relocate the Battery (probably up under the dash in a custom welded cage) and I want to mount a second "stock" Fuel tank under the driver's side seat..now upon close observation and measuring it can be reversed with a small cutout to the front but under the drivers legs only about 3" sticking out (I plan to Plastic weld a cover piece..The plan is to install a 12V pump and switch mechanism and all of the proper brackets ect.. I just need a fuel tank with the top not the internals, although if you have one laying around that you don't need with internals , I can fiddle with that and see about actually running dual saddle back tanks..The idea here is that the fuel which weighs the most is at the lowest point..it's just over 7 gallons (60Lbs) non-visible extra gasoline and if I start to run low, I can just "flick" a switch and fill my main tank without even getting out of me seat...Like I said this is going to be a well documented experiment/project..I will add it to my build thread..I will pay for all shipping expenses..
I've "pay'd it forward" many of times and will continue. let's see if we can get this project started! If done right..with proper steps and instruction, this could be a solution to a lot of you who go on long rides and can't stand strapping on extra fuel cans!
Thanks guys, Mike
Already spoken for.
Thanks again Jim. :)
I need one 1 1/2" wheel spacer, Palm Desert, CA 92260
I got a 08 orig skid plate a bit used but still good for the taking ;-)
Save
