P0030 Oxygen Sensor Code?
8.8K views 3 replies 2 participants last post by  metro
Hi,
I have a 2019 Turbo S4 and recently it popped Engine code P0030: Oxygen Sensor Heater 1 (Pre) (front) code.
Any suggestions on on fixing this? It won't clear. Is the the O2 sensor on the midpipe ahead of the muffler or somewhere else?
Thanks!
Check that the O2 sensor is tight in the exhaust pipe. I had a buddy whose sensor worked it's way loose somehow and threw a code (wasn't grounding and probably leaking). I don't recall if it was the same code or not but we just tightened it down a little and it cleared the code. Worth a check. Owner's manual says torque spec is 13ft lbs
