2012 XP 900 Engine Rebuilt with the following OEM Parts... This engine will fit in either a 2011 or 2012 XP 900...
1) Head Gasket (1)
2) Base Gasket (1)
3) Oil Pump Seal (1)
4) Oil Pump (1)
5) Oil Pickup Tubes (2)
6) Oil Pump Chain (1)
7) Cam Chain (1)
8) Crank Seal (1)
9) Valve Cover Seal (1)
10) Main Bearings (8)
11) Counter Balancer Bearings (4)
12) Rod Bearings (4)
13) Pistons, Rings Wrist Pins and Cir-Clips (2 sets)
14) Ignition Cover Gasket (1)
15) Oil Sump Cover Gasket (1)
16) Water Inlet & Thermostat Gaskets (2)
17) Exhaust Sealing Gaskets (2)
18) Head Bolts (6)
19) Head Screws (2)
20) Cylinder (1)
21) Crank (1)
22) Valve Job (1)
23) Tensioner & Gasket (1)
24) Oil (4 qts.)
25) Oil Filter (1)
26) Antifreeze (1 gallon 50/50 mix)
$3100.00 + shipping to the lower 48 States...
