My take on a cab heater
24K views 19 replies 9 participants last post by  Bullitt427
I am just posting this as an example of a heater setup that may help others that are interested in installing a heater in their vehicle.
The vehicle is a 2017 Polaris RZR Trail EPS.
Parts I used:
UNIVERSAL CAB HEATER UTV SKIDSTEER 12 VOLT 16,000 BTU-- EBay - $190
3/4 NPT 3-Way Forged Brass Ball Valve -- $25
2 - 3/4 NPT 1" Barb - $1.25 ea
1 - 3/4 NPT 5/8 Barb $1.25 ea
1 - 3/4 NPT 5/8 Barb Elbow - $1.25 ea
2 - 90 degree 5/8 elbows - $1.25 ea
1 - 1" Male 3/4 NPT Female 1" Male $0.80
8 - Small clamps - $0.80 ea
4 - Medium clamps - $1.00 ea
5/8 Heater Hose $10
Total = 252.70
I started by mounting the bracket for the heater in the cab.
I placed washers beneath the bracket to raise it up a bit over the point on the center tunnel.
After attaching the bracket I mounted the heater core to get an idea of where I needed to drill the holes in the firewall to run the heater hose.
After taking the measurements I drilled 2 holes to pass the heater hose through.
Next was cutting the OEM radiator hose, and installing the 3-way. I cut the OEM hose around 6 inches up, so the hose started to point up when turned.
I then cut a small piece just big enough to fit both 1" barbs of the 3-way, and the T fitting. I had to remove another approximately 6 in section after the T fitting to get the OEM radiator hose to be in the proper angle back to the radiator.
After the 3-way, and T are in place you can measure and cut out the 5/8 heater hose to the proper length. I used a small piece of heater hose to install the 90 degree elbows above the inlet, and outlet of the heater core.
I finished off running the wires to a rocker switch in the dash to turn the fan on and off, as needed.
To bleed the system, after refilling the radiator with coolant, I found it easiest to just jack up the front of the RZR with the radiator cap off, and let the vehicle run. When the thermostat opens, and sucks the coolant into the system, simply keep filling the radiator until no more is needed. I bleed the system in the bypass heater core position first, then diverted to the heater core, going back and forth every couple fan cycles until I was sure there were no air bubbles in the system.
I tried to use the bleeder screw by the exhaust port, but I was not very successful. The bolt needs to be turned almost all the way out for coolant to flow out, which is very difficult with the added heat shielding in the way. I may have also turned the bolt to far out, and dropped it on the skid plate a few times before giving that idea up.
All in all the project took me a couple hours, and was not that difficult. This setup allows me to bypass the heater core during summer to keep the cab from overheating, while still allowing me to turn the fan on to get some much needed circulation in the foot area of the vehicle. If we decide to go on a night ride, and it gets a little chilly, one simple flip of the valve allows either some radiant heat, or forced heat via fan. It is very nice in the winter also, you can see heat waves billowing out the cab when stopped.
#2 · (Edited)
Nice work.
I just installed the Polaris factory heater in mine, it was $539.
The heater itself mounts up under the dash so you dont see the actual heater.
You have to remove upper and lower dash assembles, cut a holes in both so that in itself is scary.
I measured 3 times and cut once......
Has heater vent and defrost vent, it is a nice clean package but you saved half.
Photo not the best but you can see the heater and defrost vent
Nice, I like the defrost option on yours. I personally don't have a full windshield, and kinda like the feeling of not having one. I second guess this sometimes in the rain though. LOL If I do ever get a full windshield, I will have to come up with a way to channel some heat up there, but that is another project all together.
I personally like tinkering, so that is why I decided to try building my own system. The fact it cost half what some of the other units costed was definitely a factor. I wanted to tuck it up a little higher, but couldn't find a heater core with the dimensions I wanted. So I settled with the one I got. Works good, still out of the way of foot, and doesn't look super terrible. :)
You have a heater without a windshield [emoji848] Windshields work really well worth the cash
Looks like a good set up.
If you were inclined to do so you could probably use an electric solenoid valve instead of the ball valves and have the coolant flow into the heater with the control of a switch. Just a thought.
I looked into that, it would be nice, but I don't really switch it back and forth all that often. During the winter it is always running to the heater core. During the summer, the only time I see myself running it to the heater is during a night ride that gets a little chilly.
The solenoids that I found were also around $200.00 - $400.00 so it would have increased the cost of the build by quite a bit.
This guy made one for under $100, and he just rerouted the current coolant hose, I cut both my top and bottom radiator hoses
Could fab a box and mount heater anywhere.
Good idea on his mounting but on mine you couldn’t check the oil.
https://youtu.be/TkXpzDznE_Q
Haha, I watched that one when I was trying to find some ideas. You can makes some cool stuff for really cheap. Only problem with that one that I saw was that on my machine there is no where near that much space behind that access panel. There is a bunch of heat shielding, dipstick, and exhaust right where he put that I believe, and you can't shut it off. :) Awesome idea though.
Also without a fully enclosed cab, I don't know how effective that would be blowing from that spot.
That's a pretty neat idea. I looked into electric heaters, and they all required way to many amps to generate any heat. Was afraid the battery would drain if I went electric. You have any idea what that blanket draws? I will pass this idea on to some friends that don't want to spend the money on a heater, but may go for a heated blanket. Then they may ride more in the winter with us. :)
I have a Motoalliance Firestorm under dash heater.
Enclosed cab and sealed up all the cab leaks/gaps were cold air can get in.
Makes good heat and with the cab sealed up we stay warm and dry all winter.
I seen a poor mans heater setup that was very effective and cost next to nothing.
He took a 3" dryer hose attached it to the rear of the radiator, routed it through the firewall with a 3" RV sewer gate valve to turn it off and on.
He said it worked excellent....DRK
