Back to the build:
After removing the head you pull the cylinder block.
Here is what you will have when the pistons are in the down position:
And in the up position:
I took Dogo X's advice and installed the new dipstick and oil supply line while the head cylinder block was removed:
EDIT: After finding a washer with a rubber seal in the parts bag and consulting MCX, I learned that this washer is installed on the adapter for the oil supply line. Here is how that end of the assembly installs:
End of edit.
After a little cleanup, you are now ready to install the shim.
You need more than both hands to do the next step, so I didn't take any pictures.
It is my understanding that there are two methods of reinstalling the cylinder block on top of the shim:
Option 1: Remove the heads of the pistons by pulling the retaining clip and pin, installing the pistons into the cylinder block, then holding the cylinder block with the piston heads inside it above the engine, reinstall the pins and clips that connect the piston heads to the rods, and set the cylinder block down on the shim. (Don't drop the clips down into the engine if you choose this method. Cover the engine cavity with a towel to catch anything you drop.)
Option 2: Leave the piston heads on the rods, hold the cylinder block above the engine and feed the piston heads into it by compressing the piston rings and slide the cylinder block down on the shim.
I tried to pull one of the clips that holds the pin into the piston head, but didn't have any success. Maybe it requires a special tool or "know how" that I don't have. So I abandoned option #1 and went with option #2. You will need an extra set of hands, or two, for this step. I had one helper (thanks Don!)
I sprayed the shim with copper coat.
Tip: This is something that does not currently come in the kit so you will need to get it at your local auto supply store.
Link to Permatex product:
Permatex
EDIT:
VERY IMPORTANT! LET THE COPPER COAT SET UP BEFORE INSTALLING THE SHIM (This may take SEVERAL hours, depending on your ambiant temp and humidity). READ THIS WHOLE THREAD AND YOU WILL SEE WHY!
End of edit.
Once both sides of the shim are prepared, install it on the engine and procede with the sequence described in option #1 or #2 above, I chose #2.
The hardest part of the cylinder block installation is compressing the piston rings on both pistons at the same time and getting both of them to slide back into the cylinder block. I don't think I could have done it alone. It took about 5 minutes with two of us working on it, but we got everything lined up and slid into place without causing any damage (that I know of).
Once the cylinder block is in place the rest of the engine assebly is easy.
Install the new head gasket and the head and just reverse the process of taking the head off following the torque requirements as shown in the service manual. After the valve cover is back on, it looks like this again:
:rzrs:
