I have a 13 xp4 900 with a 16 1000 engine. Went to glamis in January and towed a 2 seat rzr from
Olds to gecko. The next morning went to start the rzr and would crank no start u till I gave it some gas then seemed to run fine. Went on a long ride ( gecko down to the Gordon’s well) half way back stopped for a pee break let car idle and it shut off Went to start it and would jot start. Got it towed back to camp tested for spark good tested for fuel good got it home put new crank position sensor nothing. Did compression test. 30 psi on both cylinders. Timing is good valve clearance is good. No holes in the pistons any recommendations on what to check test next.
